'96 wheel center cap rubber O-ring seal? - NCRS Discussion Boards
  • Paul S.
    • December 13, 2013
    • 83
    I just obtained a correct set of 5 spoke wheels and center caps for my '96 CE. One of the Corvette parts vendors lists a rubber O-ring seal for these caps. My question is; did they come with these seals from the factory. Just curious...the judging manual doesn't specify. Thanks, Paul
  • Tom H.
    • December 1, 1993
    • 3440
    Re: '96 wheel center cap rubber O-ring seal?
    No O ring that I remember. Snap in caps.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Paul S.
      • December 13, 2013
      • 83
      Thanks Tom. BTW...my car has a BUDS emblem under the hood centered along the top inside edge (hood open) . I suspect it was originally purchased from BUDS.
      • Tom H.
        • December 1, 1993
        • 3440
        I bet I sold it new. Any idea who's it was ?? I may have a picture of it with the original owners !!
        Tom Hendricks
        • Tom H.
          • December 1, 1993
          • 3440
          PM me the VIN if you like. I can see if I have anything on it !
          Tom Hendricks
          • Tom H.
            • December 1, 1993
            • 3440
            Hi Paul ! Just noticed my inbox here was full. I just cleaned it up. You can PM me your email and I will send you the records I have.
            Tom Hendricks
              • 43247
              Paul------
              The 1996 wheels did not use an o-ring seal for the center cap. However, the 1988-89 QA1, 17" wheels did use such a seal. These caps, GM #10055340 and about 150 bucks each GM list at the time they were discontinued, were among the most expensive caps ever used on a Corvette aluminum wheel. The o-ring seal was GM #10097592, also now discontinued.
              • Paul S.
                • December 13, 2013
                • 83
                Joe, Thanks, that helps clear up the confusion. The catalog I was checking out had them mislabeled...Paul
