Alternator Help 1963 - NCRS Discussion Boards
  • Daniel S.
    • December 10, 2013
    • 24
    Hello, I am restoring my 1963 SWC. It is the original alternator and an early 1963 car. The engine compartment is detailed well but the alternator isn't nearly as nice as everything else in the engine compartment. I would like to get it rebuilt and have it refinished ASAP. I have done some research and cant find anyone that can do this. I live in CT but can ship it wherever, as long as you guys recommend the shop or person. I really appreciate everyone's help and insight! You guys have been fantastic! Thanks, Dan
  • Donald O.
    • May 31, 1990
    • 1593
    Re: Alternator Help 1963
    John Pirkle
    Have him do your voltage regulator as well at the same time.
    DonO
    • Gene M.
      • April 1, 1985
      • 4233
      Use caution here as restorers are known to use incorrect INA bearing for Torrington. Also diodes should not have a chromate s/b just zinc. The field steel laminations in 63 s/b black. Lastly the die cast case s/b as cast smooth finish no secondary surface finishing.
