engine suffix code label fr bb 1970 - NCRS Discussion Boards
  • Gus T.
    Infrequent User
    • July 15, 2007
    • 6
    Does anyone know where I can get an engine suffix code label for a 1970 Big Block? Thanks Gus 47583
    1970 National Top Flight Coupe BB
    1971 Big Block Convertible
    1973 project coupe
    Mason Dixon NCRS Chairman
  • Ron G.
    • December 1, 1984
    • 866
    Re: engine suffix code label fr bb 1970
    Gus - Yo umay want to reach out to Patrick Hulst. His email address is: corvettestickers@gmail.com.
    "SOLID LIFTERS MATTER"
    • Gus T.
      Infrequent User
      • July 15, 2007
      • 6
      Thanks Ron.
      1973 project coupe
      • Donald A.
        • January 7, 2013
        • 239
        Question for the less informed
        what are you talking about exactly.
          • 11698
          Stickers placed on the engine at the assembly factory, usually on the rear of the passenger's side valve cover but occasionally on the front as well. They contain the suffix code of the engine, and at times other information as well.
          FYI they are still being installed to this day. I took a photo of this one at the Engine Build plant in Wixom back in 2011.
          Patrick
            • 3422
            Hi Donald,
            Here's the original from my 71 base engine car.
            • Paul O.
              • August 31, 1990
              • 1716
              One reason these labels were used so the employee could locate the engine need for the next car on the line for build. This type of labeling or marking on components was used in many areas Transmissions, Rear Axles, etc. He could locate what was needed by just looking at the large 2 or 3 letter code to find the correct engine. Other wise he would have to look at the small code stamped into the engine block. It was all about speed and ease of production.
              • Donald A.
                • January 7, 2013
                • 239
                Thanks all. Had no idea. Is this something that is part of judging? Don't recall it in JM
                  • 15643
                  Yes it is part of judging and it has its own line on the judging sheets. It is one of the more common total deductions (requiring Team Leader sign-off) when it is missing. You might want to get the on-line copy of the Judging score sheets from this site.
                  NCRS Site Cliff Notes:
                  Hold your cursor over the radio button above titled MEMBER SERVICES. Second from the bottom item is JUDGING SCORE SHEETS. Click there and the world of Corvette judging is at your fingertips (well your cursor anyway). The suffix label is in the MECHANICAL score sheets, right below the ROCKER COVERS.
                  • Donald A.
                    • January 7, 2013
                    • 239
                    Thanks so much Terry and great to see you at TX Regional.
                    BTW, and this is just my opinion, but whoever runs the technical side of this board needs to address the ability to upload pics. Way behind the times regarding data limits. This board is fantastic and the folks are great but it could be so much more helpful with more pics. I run two other boards, PhPbb, and host with Go Daddy. Data storage is getting cheaper all the time. Surely we can afford to up the capacity.
                    • Don H.
                      Moderator
                      • June 16, 2009
                      • 2284
                      Don,
                      the IT team has addressed the storage capacity, but not publicized it. I don't think there is a any longer a four photo limit. In the Test Forum a couple guys have uploaded a dozen or more images.
                      good to see you at Frisco.
                      • Donald A.
                        • January 7, 2013
                        • 239
                        Don, what I was really referring to is the download limit regarding the file size. The limited size means that you have to convert all files to a much smaller file size in order to just try an upload. The limit should be increased to at least 5mb.
                        It's also useless and completely outdated to have pic setting at under 100kb. This does not allow good review of existing pics. I know enough to know that these are just settings on the back end admin side. If we need more space then they need to increase it.
                        • Joe R.
                          • May 31, 2006
                          • 1822
                          Don,
                          Good thoughts, but posting them here won't garner you much more than sympathetic posts like this one. Send a note to your regional director, see what happens!
                          Joe
                          • Kenneth H.
                            • October 27, 2008
                            • 500
                            I know that it has been discussed before, but I've forgotten and was wondering what material was used to attach the label to the valve cover?
