1966 corvette water pump - NCRS Discussion Boards
  • Richard B.
    • August 6, 2014
    • 14
    can anyone provide a picture of a correct big block water pump back plate for a 66 cant find anything in the archives Thanks in advance, Rich
  • Richard B.
    • August 6, 2014
    • 14
    Re: 1966 corvette water pump
    Wow ....anyone
    • Joe R.
      • May 31, 2006
      • 1822
      Rich,
      I can't help with your request, but what is the GM # of the water pump? Try plugging that into the search box, I think you may find your answer.
      Joe
      • Jim S.
        • March 1, 1986
        • 1402
        Richard,
        I can't help with the "correct picture" for your application, but if you advance search this title , you will see all the backing plate types . If I recall from searching for my 66 , 66 is a pivotal year between the flat and the first ridged plates . Also between the slotted screw and the bolts.
        Re: Small Block Water Pump Backplates!!!!!
        Hope this helps ,
        Jim
        • Richard B.
          • August 6, 2014
          • 14
          Thank you for your reply Jim, my water pump has slotted screws but has a ridged plate water pump casting #3856284 cast K 8 5 Rich
          • Richard B.
            • August 6, 2014
            • 14
            Thanks Joe ,water pump casting #3856284 shows no results
            • Donald H.
              • November 2, 2009
              • 2580
              RIchard if you search by just entering the number 3856284 you will get a lot of hits. I saw one picture of what the poster said was an NOS 385284 and it had bolts and the ridged backing plate. Another of one that had a late 65 date and it had pan head slotted screws with the ridged backing plate.
              Don
              Don Harris
              • Richard B.
                • August 6, 2014
                • 14
                Thanks Don , I will try that,Rich
                  • 43222
                  All------
                  The 3856284 casting was used for all big block waterpumps from 1965-68 and for all short-leg applications for early 1969. The configuration of the assembled pumps changed in minor ways over the period.
                  • Jim S.
                    • March 1, 1986
                    • 1402
                    Then I would say it is the correct backing plate for a late 65 .Of course the only correct plate for judging is whatever the JG says it should be ! Also advance search this title for photos
                    67 Big Block water pump
                    Jim
