can anyone provide a picture of a correct big block water pump back plate for a 66 cant find anything in the archives Thanks in advance, Rich
1966 corvette water pump
Tags: None
- Top
Re: 1966 corvette water pump
I can't help with your request, but what is the GM # of the water pump? Try plugging that into the search box, I think you may find your answer.
Joe- Top
Richard,
I can't help with the "correct picture" for your application, but if you advance search this title , you will see all the backing plate types . If I recall from searching for my 66 , 66 is a pivotal year between the flat and the first ridged plates . Also between the slotted screw and the bolts.
Re: Small Block Water Pump Backplates!!!!!
Hope this helps ,
JimLast edited by Jim S.; October 25, 2014, 12:29 PM.- Top
Thank you for your reply Jim, my water pump has slotted screws but has a ridged plate water pump casting #3856284 cast K 8 5 Rich- Top
- Top
RIchard if you search by just entering the number 3856284 you will get a lot of hits. I saw one picture of what the poster said was an NOS 385284 and it had bolts and the ridged backing plate. Another of one that had a late 65 date and it had pan head slotted screws with the ridged backing plate.
DonDon Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
All------
The 3856284 casting was used for all big block waterpumps from 1965-68 and for all short-leg applications for early 1969. The configuration of the assembled pumps changed in minor ways over the period.In Appreciation of John Hinckley- Top
Then I would say it is the correct backing plate for a late 65 .Of course the only correct plate for judging is whatever the JG says it should be ! Also advance search this title for photos
67 Big Block water pump
Jim- Top
