C1 Engine date code - NCRS Discussion Boards
C1 Engine date code
  • Steve M.
    • March 17, 2013
    • 5
    C1 Engine date code
    My 1959 built Nov.58 has E158 on the block.Could this be the original engine?Thanks. Steve.
    Re: C1 Engine date code
    Steve -
    Which engine is it, and what's stamped on the front pad?
    • Dan A.
      • May 31, 1974
      • 1074
      Due to the May casting date it may be helpful to clear up if it is a 519 or a 739 block.
      • Steve M.
        • March 17, 2013
        • 5
        Steve -
        Hi John. Casting no. 3737739. Front pad F 1029 C T . Thanks. Steve.
        • Steve M.
          • March 17, 2013
          • 5
          Hi Daniel. Casting no. 3737739 . Front pad F1029 CT. Thanks. Steve.
            • 43242
            Steve------
            I think you're reading the block casting date incorrectly. I believe the last number is a "9", not an "8". In any event, the assembly date stamped on the block looks like it's a May, 1959 date (although the day doesn't make sense with 3 digits). Also, the "CT" suffix code is a code for a 1959 Corvette 245 HP engine. So, everything seems to "line up" and this is likely the original engine.
            • Thomas H.
              • August 31, 2005
              • 1060
              F 1029 CT = Flint, Oct 29, CT = 2x4, 245hp, Manual trans. The "1" in the 10 should look like a capital "I"
              The block casting date of E158 works out to be E = May, 15, 1958.
              If this is really the case, the engine build date would align with a Nov 58 build date, but the casting date is off.
              Double check these and post a picture or two if you can.
              All of the info you need is in the TIMJG for 58-60 (which is where I got my info from)
              Tom
              2007 Z06, Lemans Blue
