Crack in 69 Shifter Console - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    What would be the best glue/technique to repair this crack in the shifter console? Luckily it does not affect the vinyl overlay. Thanks
    Edit - title should read Shifter Console - thumb got in the way
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Crack in 69 Shifter Console
    Roger,
    I would put slow cure JB weld in the crack and saturate some fiberglass cloth with JB and cover the crack with the cloth.
    Dom
    • Mark D.
      1984-96 Team Leader
      • June 30, 1988
      • 2168
      This is good stuff...
      Kramden
        • 43277
        [ATTACH=CONFIG]55676[/ATTACH]
        Roger------
        I've used fiberglass cloth and resin to repair forward console substrate damage/cracks.
        • Russ S.
          • April 30, 1982
          • 2163
          Agree with Joe. I have also used fiberglass mat and resin. Be sure to scuff it very well though.
          • James B.
            • March 1, 1985
            • 217
            Fiberglass mat or fiberglass cloth?
            • Russ S.
              • April 30, 1982
              • 2163
              Never cloth. Cloth is for boats. Mat is far better and far easier to use.
                • 43277
                Russ and James-----
                I've used cloth and it worked very well. However, mat may be better and easier.
                • Roger G.
                  • October 11, 2012
                  • 268
                  I went with cloth, it's what they had at ACE. I've never worked with fiberglass, but it wasn't too hard. Roughed up the surface, cut out three patches and laid them on foil, spread the resin on the patches and crack, and laid them out on layers. Will see if it holds when the clamp comes off
                  • Roger G.
                    • October 11, 2012
                    • 268
                    Roger------
                    Joe, it turned out great,, no movement with the clamp off. Sturdy when flexed open, thanks
                    • Rich C.
                      • January 1, 1994
                      • 383
                      Hmmm...I see your using your Restorer magazine as a drop cloth? (just kidding) Repair looks great!
                      1973 LS-4 454 coupe owned 24 years
                      1996 LT-4 Collector Edition coupe owned 14 months
                      Sierra Nevada Torpedo IPA-currently on tap!
