70 L46 Passenger side Exhaust Install (Heat Riser) - NCRS Discussion Boards
    • 43222
    Re: 70 L46 Passenger side Exhaust Install (Heat Riser)
    Originally posted by Bill Lennox (41387)
    I have both sleeves now and they are a much higher quality than is provided by an otherwise excellent vendor.
    They are a pretty snug fit and I had to tap them in place. Does that sound correct? How much of the sleeve should stick out above the donut?
    Bill
    Bill------
    The GM extensions (sleeves) did not have to be tapped in. However, if they do need to be tapped in that's no problem, at all. They should work perfectly.
    With the GM extensions, only a very small amount usually protruded above the packing (donut). However, more than this should also cause no problem, whatsoever. The portion above the packing adds nothing of functional value but it doesn't cause any functional problem, either.
    • Bill L.
      • February 1, 2004
      • 1403
      Bill------
      Thank you Joe.
      Bill
      • Timothy B.
        • April 30, 1983
        • 5186
        These extensions serve the purpose of centering the pipe to heat riser as well as centering the packing (donut). Without them sometimes the heat riser valve will not open and close cleanly, it's very important to have these.
          They also reinforce the I.D. of the donut, preventing it from disintegrating inward from the clamping forces acting on the chamfered upper and lower surfaces.
          • Timothy B.
            • April 30, 1983
            • 5186
            Right you are John, I missed that important detail. Glad you mentioned it.
            • Bill L.
              • February 1, 2004
              • 1403
              Thank you for all the info. It is a good day when you learn something new.
              Bill
