1967 L68 400hp Stamp Pad - legitimate or a re-stamp? - NCRS Discussion Boards
  • Mark S.
    • January 26, 2013
    • 88
    I would appreciate your insights as to the legitimacy of the stamp pad surface and stampings for the attached 1967 L68 400hp car. Does anything look suspicious/out of whack? Many thanks in advance.
  • John S.
    • May 17, 2009
    • 164
    Re: 1967 L68 400hp Stamp Pad - legitimate or a re-stamp?
    Mark,With all the other stuff apparently not correct on this car, why would you continue to look at this car? Get one that is authentic, with validated tank sticker so you know the facts. John
    • Michael J.
      • January 27, 2009
      • 7155
      • Joe R.
        • July 31, 1976
        • 4551
        Run Forest Run!!!!!
        They ain't never been a big block stamped that good in history!!! From the factory that is!!!!!!
        JR
        • Richard L.
          • May 31, 1988
          • 156
          Originally posted by Joe Ray (1011)
          Run Forest Run!!!!!
          JR
          Ditto..!!!
          • Bob H.
            • July 31, 2000
            • 823
            My real L68 air car never looked nearly as good!
            • Ron G.
              • December 1, 1984
              • 865
              I am not a pad expert, but I'm with Bob H. Look at not just the spacing of the characters, but each one looks to be the same depth. A little too good.
              "SOLID LIFTERS MATTER"
              • Terry D.
                • May 31, 1987
                • 2696
                Buy the darn car, you know you want it, you keep looking for reasons to buy it. Will you be disappointed if you have it judged? YES will you have fun with the car driving it? YES You have to decide which is more important to YOU, having a "correct car" or having the one you want and can afford. It's pretty clear you are not listening to the others so I thought I'd play devils advocate!
                • Bill K.
                  • June 27, 2013
                  • 48
                  Here is a photo of my stamp pad. I believe Tim Gilmore has a similar pad in the same early serial number range.
