58 Heads - NCRS Discussion Boards
58 Heads
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: 58 Heads
    As I remember the only staggered valve cover bolts were 1955 to 1957. 1958 on used the bolts directly across from each other.
    Dom
    • Thomas H.
      • August 31, 2005
      • 1068
      Re: 58 Heads
      Dom
      staggered were also used in 58 and early 59 before the switch over to the different head casting.
      2007 Z06, Lemans Blue
        • 43273
        #18
        Re: 58 Heads
        Originally posted by Brad Hake (47659)
        OOOps... John, I checked the no. again and it is the single digit K127 not the K1257 and the end symbol's are very smooth. Correct? Thank you.
        Brad-------
        In this case, I cannot understand why the heads received such a deduction as you described.
        • Steven B.
          • June 30, 1982
          • 4010
          #19
          Re: 58 Heads
          What was noted as the reason for the deduction?Steve
          • Brad H.
            • August 12, 2007
            • 724
            #20
            Re: 58 Heads
            Naturally they went by the book without really knowing. They saw the mountain looking end symbol as for the 58 and the triangle for the later year's, not asking about the nos. They said head's were probably Pass. car. 7/10 of point could throw a guy into second flight pretty easy if score were close. Did not happen here though. Looking for an original pan (58) or one that will pass judging also. Thank you. Brad.
              Re: 58 Heads
              Brad -
              Yes, that's correct - what was the nature of the deduction?
