58 Heads - NCRS Discussion Boards
58 Heads
  • Brad H.
    • August 12, 2007
    • 724
    58 Heads
    Hi. My Head's read 3748770 x58 on side with the triangle on each end, (230 horse) the Nolan Adam's book show's several instance's with this but the judging book show's a different end marking. I had a 30 point deduct at a recent Regional. Were they wrong? Thank you.
    • 43273
    Re: 58 Heads
    Brad-------
    Do the heads have accessory bolt holes on the end? Are the heads Tonawanda-cast or Saginaw-cast?
    • Brad H.
      • August 12, 2007
      • 724
      Re: 58 Heads
      Hi Joe. Head's also have the staggered hole's for valve cover's, no end hole's for access. What determines the cast town? Again mine have the triangle cast on the end's. Thank you.
      • Thomas H.
        • August 31, 2005
        • 1068
        Re: 58 Heads
        The correct heads will have a smooth or machined surface on the end markings. A shot of my 58 heads
        2007 Z06, Lemans Blue
        • Brad H.
          • August 12, 2007
          • 724
          Re: 58 Heads
          Hi Tom... My head's look the same as your's with the triangle sitting on rectangle very smooth and 770 #. Does that mean their correct? Thank you.
            • 43273
            Re: 58 Heads
            Brad------
            Under the valve cover (where the casting number and dates are found) is there anywhere to be seen a large "T"?
            • Brad H.
              • August 12, 2007
              • 724
              Re: 58 Heads
              Will look in the morning.
              • Thomas H.
                • August 31, 2005
                • 1068
                Re: 58 Heads
                "Correct"......??
                I can't say for sure as I am not a judge nor have I had my heads judged, but from what I know and have learned these are the right heads for the engine. I would not expect any deducts on my heads when judging time comes. March 58 car, late Jan 58 heads, but casting dates are not visible during judging as you are aware.
                Tom
                • Brad H.
                  • August 12, 2007
                  • 724
                  Re: 58 Heads
                  Hi Tom... My heads are dated K1257 for a Dec 14 car.
                  • Brad H.
                    • August 12, 2007
                    • 724
                    Re: 58 Heads
                    Hi Joe... No T anywhere, k1257 date for a Dec 14 57 build 58 car. Thank you.
                    • Jim L.
                      • September 30, 1979
                      • 1817
                      Re: 58 Heads
                      A two digit year, such as "57" on your heads, indicates they came from Tonawanda, never a source for small block Corvette engines. Some Tonawanda heads (notably '57, but possibly others) have end symbols which are detectably different from those on Flint heads.
                        Re: 58 Heads
                        Brad -
                        Those are Tonawanda heads, and the raised symbols on the end of the heads will have an as-cast surface; the end symbols on Flint heads will have a smooth machined surface.
                        • Thomas H.
                          • August 31, 2005
                          • 1068
                          Re: 58 Heads
                          Both Jim and John are correct. Corvette heads would have a single digit for the year. So your K1257 heads would be K127 if they were Flint Corvette heads.
                          Tom
                          • Brad H.
                            • August 12, 2007
                            • 724
                            Re: 58 Heads
                            OOOps... John, I checked the no. again and it is the single digit K127 not the K1257 and the end symbol's are very smooth. Correct? Thank you.
                            • Brad H.
                              • August 12, 2007
                              • 724
                              Re: 58 Heads
                              Tom... I rechecked the no. again and it is indeed a single digit K127. with very smooth end symbol's. Thank you.
