Early C3 driver inner fender - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    This is a driver side inner fender from an early C3. Note the slot circled in red. There is also a metal support riveted around the upper margin of the slot. This doesn't look correct for 69, or is it? If not, what year(s) is it from and what was the purpose of the slot? thanks
  • Thomas F.
    • November 11, 2008
    • 204
    Re: Early C3 driver inner fender
    Not sure but maybe it is the bracket where the headlight dimmer switch petal connects. Looks like that is about the location where it is located on my 69.
      • 3416
      • Russ S.
        • April 30, 1982
        • 2162
        I have seen this before but can't recall what year car. I have an original no hit 70 in the shop now that doesn't have it.
        Originally posted by roger gleason (55547)
        This is a driver side inner fender from an early C3. Note the slot circled in red. There is also a metal support riveted around the upper margin of the slot. This doesn't look correct for 69, or is it? If not, what year(s) is it from and what was the purpose of the slot? thanks[ATTACH=CONFIG]55026[/ATTACH]
        • Roger G.
          • October 11, 2012
          • 268
          Alan, here is a bigger picture, showing the inner fender sitting up with the hood support mount on top. I am thinking this is a 74-79?
            • 3416
            Hi Roger,
            Now I see it and I'm still puzzled !
            I really don't know very much about the later 70 cars, but it's later than 71 also.
            Sorry I can't help with an answer.
            • Thomas F.
              • November 11, 2008
              • 204
              Sorry Roger, I really goofed on this one. Just had a senior moment.
              • Russ S.
                • April 30, 1982
                • 2162
                Bingo Rodger. Checked my 73 and 74. It started in 73 with the urethane front bumper. The bumper support tube mounts to the frame through the inner slot.
                Alan, here is a bigger picture, showing the inner fender sitting up with the hood support mount on top. I am thinking this is a 74-79?[ATTACH=CONFIG]55070[/ATTACH]
                • Roger G.
                  • October 11, 2012
                  • 268
                  Thanks Russ, looks like I have an OEM door stop in excellent condition
