Mounting bolts for my John Pirkle Starter - NCRS Discussion Boards
  • Roger D.
    • June 3, 2014
    • 180
    I am having trouble with mounting bolts because most vendors show 68-74 427/454 70-74 350. No 68/69 350. The bolts look to be both long, is that correct. The 2 I received were 1 long 1 short. The short does not work.
    • 43219
    Re: Mounting bolts for my John Pirkle Starter
    Roger------
    The bolts you require are 3-5/8" in length and have knurling on the shank. Such bolts are easy to find in a good auto parts store. Your starter nose should be cast iron.
    The short bolt, long bolt (longer than 3-5/8") configuration starter nose was used on NO 1969 Corvettes except L-88 with manual transmission.
    All 1968 327's do use the short and long bolt starter nose configuration.
    • Roger D.
      • June 3, 2014
      • 180
      Roger------The bolts you require are 3-5/8" in length and have knurling on the shank. Such bolts are easy to find in a good auto parts store. Your starter nose should be cast iron.The short bolt, long bolt (longer than 3-5/8") configuration starter nose was used on NO 1969 Corvettes except L-88 with manual transmission.All 1968 327's do use the short and long bolt starter nose configuration.
      Thanks again Joe for your help. I will track them down. I wish I had a 69 L88, that would be nice.
        • 43219
        Roger------
        Well, you've got the starter bolts for one so now you might just as well go out and buy the L-88.
