c2 big block heat riser value question - NCRS Discussion Boards
  • Michael F.
    • 745
    friend has 55-67 big block heat riser and also the big spacer that would replace heat riser, which would be a better to get and keep, I don't need either, just curious.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • James W.
    • December 1, 1990
    • 2655
    Re: c2 big block heat risor value question
    If you don't plan to judge the car, I'd go with the spacer. I actually have been looking for one (a spacer) for my '65 396.
    James
      • 43219
      James
      James------
      No original 1965 L-78 ever used the spacer so originality of the spacer must not be an issue if one is used. The reproductions are near-perfect anyway, so you shouldn't have any difficulty getting one if you want one.
      • Leif A.
        • August 31, 1997
        • 3627
        Re: c2 big block heat riser value question
        And, we all know you meant '65-'67...my fingers get "fat", too
        Leif
          • 15669
          It's easy to remove the valve from the shaft, which effectively, makes it the same as the FI spacer, but it's looks correct from the outside.
          • Michael F.
            • 745
            just now noticed I said 55 and yes meant 65....must be computers fault.
            Michael
