friend has 55-67 big block heat riser and also the big spacer that would replace heat riser, which would be a better to get and keep, I don't need either, just curious.
c2 big block heat riser value question
Tags: None
- Top
Re: c2 big block heat risor value question
James------
No original 1965 L-78 ever used the spacer so originality of the spacer must not be an issue if one is used. The reproductions are near-perfect anyway, so you shouldn't have any difficulty getting one if you want one.In Appreciation of John Hinckley- Top
Re: c2 big block heat riser value question
just now noticed I said 55 and yes meant 65....must be computersfault.
Michael
70 Mulsanne Blue LT-1
03 Electron Blue Z06- Top
