69 S/B Hood - NCRS Discussion Boards
69 S/B Hood
  • Roger D.
    • June 3, 2014
    • 180
    69 S/B Hood
    There is a press molded S/B hood for sale on the forum. Person said he bought it off a 69. Should it have a part # somewhere. Claims that press mold was the process used at the factory, its the real deal. Just trying to get an original.ThanksRoger
    • 3416
    Re: 69 S/B Hood
    Hi Roger,
    I don't think the hood has a part number on it anywhere.
    The part number in the AIM is for the hood 'assembly', not just the 2 molded fiberglass pieces.
    I did find a number on my 71 hood which I've thought might identify the mold used, and also, what appear to be 'usage' counts for the mold.
      • 11644
      Re: 69 S/B Hood
      I don't know of a part number, but here is a pic of a 72, and these numbers are typical of what I have seen. Also note the four "circles" which I assume are from the mold for the inside of the hood.
      Reproduction hoods are different in several small ways. If you can see numbers like these, the 4 circles, and can identify a bit of fiberglass weave in a few spots, it's an original.
      • Roger D.
        • June 3, 2014
        • 180
        Re: 69 S/B Hood
        I don't know of a part number, but here is a pic of a 72, and these numbers are typical of what I have seen. Also note the four "circles" which I assume are from the mold for the inside of the hood.Reproduction hoods are different in several small ways. If you can see numbers like these, the 4 circles, and can identify a bit of fiberglass weave in a few spots, it's an original.[ATTACH=CONFIG]54806[/ATTACH]
        Thanks for the picture Patrick. I guess I would need to make the 7hr trip to check it out. ThanksRoger
        • Roger D.
          • June 3, 2014
          • 180
          Re: 69 S/B Hood
          Thanks Alan for your input. I guess I would have to check it out first. Just need to know what I am looking at. Thank youRoger
            • 11644
            Re: 69 S/B Hood
            Ask for photos. For the price of a hood the seller should be more than willing to send them.
            • Jeffrey S.
              • May 31, 1988
              • 1882
              Re: 69 S/B Hood
              Roger,
              here is a picture of an original '69 small block hood numbers and circle. Hope this helps.
              Jeff
              • Wayne W.
                • April 30, 1982
                • 3605
                Re: 69 S/B Hood
                You have to be careful with this, because there were some running changes from 68 through 69 and early 70. The latch on one side is turned different and the cable mount was changed.
                  • 43222
                  Re: 69 S/B Hood
                  Wayne------
                  Yes, the quickest way to tell the difference is the cross cable retainer threaded mounting holes. The 1968-E69 has TWO such holes. The L69-76 has only ONE. The first design was used until quite late in the 1969 model year. The right side hood latches are not interchangeable between the 2 style hoods.
                  • Roger D.
                    • June 3, 2014
                    • 180
                    Re: 69 S/B Hood
                    Wayne------Yes, the quickest way to tell the difference is the cross cable retainer threaded mounting holes. The 1968-E69 has TWO such holes. The L69-76 has only ONE. The first design was used until quite late in the 1969 model year. The right side hood latches are not interchangeable between the 2 style hoods.
                    Thank you gentlemen, I will check the aftermarket hood which I am assuming has the original latches. Will check back with a picture
                    • Roger D.
                      • June 3, 2014
                      • 180
                      Re: 69 S/B Hood
                        • 11644
                        Re: 69 S/B Hood
                        Reproduction hand laid hood. It is not press molded. Pass on this one.
                        • Roger D.
                          • June 3, 2014
                          • 180
                          Re: 69 S/B Hood
                          I am sorry Patrick I should have explained better. These are my existing latches. Trying to determine if they are right. The new hood has no hardware. My hood in the pictures is from Eckler.
                            • 43222
                            Re: 69 S/B Hood
                            Roger-----
                            These latches and cross-cable are the 1968-E69 style. There should be TWO retainers with bolts that align and support the cross cable. These bolts thread into nuts "embedded" in the fiberglass (actually a nut plate behind the fiberglass, I think). So, the hood you purchase should have the same TWO embedded nuts.
                            • Roger D.
                              • June 3, 2014
                              • 180
                              Re: 69 S/B Hood
                              Roger-----These latches and cross-cable are the 1968-E69 style. There should be TWO retainers with bolts that align and support the cross cable. These bolts thread into nuts "embedded" in the fiberglass (actually a nut plate behind the fiberglass, I think). So, the hood you purchase should have the same TWO embedded nuts.
                              Great , at least the latches are good for my E69. I will make sure I can see the retainers before I drive 7hrs.Thanks Joe and everyone else.Roger
