69 rear glass shelf - NCRS Discussion Boards
69 rear glass shelf
  • Roger D.
    • June 3, 2014
    • 180
    69 rear glass shelf
    Now this is probably a dumb question, but here goes. My early 69 (Oct68) needs the rear shelf for the glass. A forum member has one with the rear mounting hinges. I have the handle and what looks like a long hinge attached to the top of the compartment. Here is the question. What size is the correct shelf. I can then decide if the one for sale will work. It seems that the 68 model year was different then 69.Thank youRoger
  • Jeffrey S.
    • May 31, 1988
    • 1898
    Re: 69 rear glass shelf
    Roger,
    I also have an Oct. '68 coupe and can take measurements for you. What measurements do you need? Length and width? I will get to this this afternoon and report back. I don't remember "a long hinge attached to the top of the compartment". I will verify later. Could you email me with your VIN?
    Jeff
    • Roger D.
      • June 3, 2014
      • 180
      Originally posted by Jeffrey Salz (13182)
      Roger,I also have an Oct. '68 coupe and can take measurements for you. What measurements do you need? Length and width? I will get to this this afternoon and report back. I don't remember "a long hinge attached to the top of the compartment". I will verify later. Could you email me with your VIN? Jeff
      Hi Jeffery, Right on the top of the compartment there is something long and looks like there is a pin in the middle. I can grab them and they pull down a little but I don't want to pull to hard. Do I have your email address??
        • 3418
        Hi Roger,
        It sounds like you may be looking at the 'flapper' doors and their mechanism which are part of the Astro Ventilation system and thinking they're a hinge. They do have a pivot which allows the doors to move but are separate from the storage shelf.
        • Roger D.
          • June 3, 2014
          • 180
          Hi Roger,It sounds like you may be looking at the 'flapper' doors and their mechanism which are part of the Astro Ventilation system and thinking they're a hinge. They do have a pivot which allows the doors to move but are separate from the storage shelf.Regards,Alan
          Oh okay that's what I was looking at. Those work with the vents on the rear lid. I need to read up on how that works. What was the thinking from GM. exhaust air flow in the cabin. Are there controls to open and close. Thanks Alan. I guess the shelf and its hardware is independent then.
            • 3418
            Hi Roger,
            The 2 flapper vents were controlled by a vacuum signal from the heater/ defroster controller on the shifter console.
            When the black 'wheel' that controls the temperature, H-C, is moved to the C (cold) setting the vacuum actuator (on the flapper door mechanism) opens the doors, and fresh air flows through the interior. The vacuum runs through a long length of copper tubing with a short piece of hose at each end.
            This system took the place of the 'vent' windows that disappeared in 1968.
            You can see the copper vacuum tube in this picture.
            • Jeffrey S.
              • May 31, 1988
              • 1898
              Roger,
              The dimensions of my shelf is:
              42 1/2" wide at the front x 20 1/2" deep. This is pretty accurate but may be slightly off since it was measured installeed and it is tight back there (at least it is for us old guys).Also attached is a picture of the hinge area. Hope this helps.
              Jeff
              • Roger D.
                • June 3, 2014
                • 180
                Roger,The dimensions of my shelf is:42 1/2" wide at the front x 20 1/2" deep. This is pretty accurate but may be slightly off since it was measured installeed and it is tight back there (at least it is for us old guys).Also attached is a picture of the hinge area. Hope this helps.Jeff
                Thanks Jeff it looks like I have at least the metal pieces on the frame that the rear brackets mount to . The person selling the shelf has the rear brackets with it so if the size checks out I will get it. Thanks fo your help and will keep you posted.Roger
