63 front springs (finish ? ) - NCRS Discussion Boards
  • Robert B.
    • March 1, 1992
    • 265
    getting ready to install my NEW 63 springs from LI Corvette they have a blackish finish on them. What would be the best thing to use for a finish and what is the actual finish for a 63 FI car.if its a natural finish should I cast blast them ? I don't want rust a couple of years from now ??? Thanks
  • Harry S.
    • July 31, 2002
    • 5344
    Re: 63 front springs (finish ? )
    Original is Natural and therefore rust. I used a good primer then a coat of stainless steel colored paint. Close but no cigar.
    • Joe R.
      • July 31, 1976
      • 4552
      Clean off the black paint with lacquer thinner or a wire brush. Assuming you have a regular suspension you should have a lavender stripe from the bottom to the top about 1 to 1.5 inches wide. Then take and spray them with a Polyurthane flat clear. That keeps them from rusting.
      Good luck,
      JR
      • Paul J.
        • September 9, 2008
        • 2091
        I'm with Joe. But some people leave them natural and coat them with an oil like WD 40 or Boeshield. It has to be recoated periodically.
