54 gas valve? - NCRS Discussion Boards
54 gas valve?
  • Guy M.
    • November 1, 1993
    • 500
    54 gas valve?
    Can a brass ball valve from the hardware store be ok for a fuel shutoff valve. Are the seals ok with gas? Its a full 1/4 inch thru and I wonder if the smaller orifice would hinder the pump to keep up. I know these cars didnt originally have one but seems it could be really handy if anythink goes wrong with the pump. Thanks again!!
  • Jim L.
    • September 30, 1979
    • 1808
    Re: 54 gas valve?
    A brass ball valve will work fine. I've had one on my FI '60 for years. It sure comes in handy if one needs to change a fuel pump or disconnect the fuel line. It could also discourage some attempts at theft.... as long as you don't reveal it's on your car.
    Jim
    • Guy M.
      • November 1, 1993
      • 500
      Re: 54 gas valve?
      Thanks Jim, I really appreciate it. I figure why not since its empty but will be put together real soon then zoom zoom.
        • 15676
        Re: 54 gas valve?
        Typical hardward store valves are designed for water systems, and any elastomers they contain may be attacked by gasoline. See if you can find one in an auto parts catalog that specifically states compatiblilty with hydrocarbons.
        If the hardware store part is all brass with no elastomers, then no problem.
