1963 Alternator Pulley for Fuel Injection - NCRS Discussion Boards
  • Richard S.
    • November 1, 2004
    • 36
    Looking for an alternator pulley for a non AC 63.
    The question is it specific to 63 Vette only or are there other cars that had it on the alternator? Per the manul it is 3 5/8 wide with a 1/2 in grove opening. Sounds a bit generic to me...how can you tell for sure it is the correct pulley?
    Thanks....
    • 15706
    Re: 1963 Alternator Pulley for Fuel Injection
    Mechanical lifter 327s used a specific large diameter alternator pulley in order to keep alternator speed under the 18,000 RPM design limit.
    I believe the pulley diameters and actual drive ratios are in most year AMA specs that you can download from the GM Heritage Web site.
      • 43247
      Thanks....
      Richard------
      The pulley was as you describe. It was of GM #3829193. It was anything but "generic" as its only applications were 1963-64 Corvette with SHP and FI. As I recall, there is no part number stamped on this pulley but I could be wrong.
      The 3829193 was discontinued in January, 1973 and replaced by GM #3871242. The latter was discontinued without supercession in 1988.
      • David L.
        • July 31, 1980
        • 3310
        I once owned an original 3829193 pulley stamped "3829193 BF" back in the 1980's or 1990's that I probably bought at Corvette Carlisle. Before I sold it I made a scaled drawing of it.
        Dave
