67 Corvette Idler Arm Boot Configuration - NCRS Discussion Boards
  • Thomas N.
    • July 31, 2002
    • 402
    Hi:
    I have three different idler arm boot configurations. One is a rounded boot with radiused ribs on it, one has a stepped top portion, and one has a more flat top portion. Which one is most typical factory production for 67? I've included a picture showing all three configurations. Thanks so much for any inputs.
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
    • 6950
    Re: 67 Corvette Idler Arm Boot Configuration
    Tom, i believe the middle boot looks correct, I can look later when I get home. and tell you for sure, I am pretty sure that boot was the same for quite a few years, My 63 and my 72 both have original idlers.
    • Stephen L.
      • May 31, 1984
      • 3162
      Tom, a photo of my original idler arm boot.....
      • Mike E.
        • June 24, 2012
        • 920
        Thomas,
        Here are some comparison photos to repo versus original idler arms. Like you I ordered a new boot too only to receive the replacement boot that was very far off from the original. In my case I was able to save the original.
        Original is on the left
        Original is on the bottom
        Mike
        • Gene M.
          • April 1, 1985
          • 4232
          Steve,
          You idler arm should be black up to just below the lower hole for mounting. The black is consistent with the rest of the steering linkage, a black goo....... It was all delivered to GM as an assembly.
          • Thomas N.
            • July 31, 2002
            • 402
            Thanks everybody for the information. My boot is workable also, so that is what will be used.
