1968 corvette roadster features - NCRS Discussion Boards
  • Brad B.
    • April 5, 2014
    • 10
    Re: 1968 corvette roadster features
    I have recently joined the North Texas chapter, and I plan to take two cars to the October Texas Regional Event.
    • Edward B.
      • March 29, 2013
      • 691
      I'm going to assume you mean red line 5600 to 7000, so again, it looks good for an L36 or an L68. The date on the diff could really help.
      The BR5410 and 50E8 don't ring a bell, so maybe someone else can comment on that.
      Ed
      • Leif A.
        • August 31, 1997
        • 3654
        #18
        Have you attempted to see if the tank sticker is still intact atop your gas tank? If you're lucky, it will still be there and give you exactly what you need.
        Leif
        • Brad B.
          • April 5, 2014
          • 10
          #19
          Leif, thanks for your reply. I have looked atop the tank with a fiberoptic camera system, and couldn't see anything but grommet and fiberglass. Do you think it is worth dropping the tank to see? Looks like a big job to me unless you are already dismantling for restoration.
          • Leif A.
            • August 31, 1997
            • 3654
            #20
            Depends. How badly do you want to know how your car was originally equipped?? If your car hasn't had any major resto work done on it since it was new, it may be a good idea to drop the tank, check for tank sticker and while you're in there change the fuel lines which may be dangerously dry rotted by now. If you have access to a lift it's not a major job. Just an idea.
            Leif
            • Michael F.
              • 745
              #21
              pull seats and the carpet up and look under there, try looking behind the speedo panel.
              Michael
              70 Mulsanne Blue LT-1
              03 Electron Blue Z06
              • Jim T.
                • March 1, 1993
                • 5351
                #22
                MY 1968's was found/discovered behind the radio and was folded.
                • Jeff P.
                  • 799
                  #23
                  68 vert. Found build sheet in between speedo and tach.
                  68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                  2014 Arctic White Z51 Vert. (Wifes)
