Z06 group 2 - 3rd vin #? - NCRS Discussion Boards
  • Ron R.
    • May 31, 1993
    • 190
    i JUST SAW THAT WITHIN GROUP 2 OF THE COVETED Z06 CARS THAT THE FIRST ONE WAS VIN # 2124 AND THE SECOND WAS VIN # 2244, ALL PRODUCED IN LATE OCTOBER, DOES ANYONE KNOW THE VIN # OF THE THIRD Z06 PRODUCED IN THIS GROUP 2 OF THE Z06 CARS.........ALL OF THESE CARS CONTAINED THE BIG TANK.......
    RON
  • Robert G.
    • May 31, 1990
    • 429
    Re: Z06 group 2 - 3rd vin #?
    Is it the Gulf Oil Z06, 2227?
    Looking for a specific collector car, automobilia lot or an upcoming or past RM auction, but aren't sure where to start? Search through the entire RM Sotheby's website with our search bar! Find exactly what you are looking for with our simple search tool.
    • Wayne M.
      • March 1, 1980
      • 6414
      Bob Jones survey shows # 2227.
      • John D.
        • December 1, 1979
        • 5507
        Is #2227 the one Rich Mason used to own. If so that car was owned by a local MD in old days. Dr. Donald Blatchley.
        White with blue strip. Blue interior. Famous car in our area in old days. Now Grady Davis of Gulf owned more than one so I may have the wrong one.
        • Wayne M.
          • March 1, 1980
          • 6414
          Anybody notice this ? In the Mecum auction listing for this Z06 #0695, look at the rear bulkhead [2nd thumbnail with my crude lime green arrows]. You can clearly see the 4 vertical depressed channels in the panel that are on all C2's. (I'm guessing that it's a strength or anti-vibration measure).
          Now in the AIM (at least for '65 and I'm sure that it's the same for '63), there's a note to "FILL WITH BOND" [UPC N03 sheet 3]. This would be for cosmetic reasons (ie no carpeting to hide them), but mostly to provide a perfectly flat surface that the cover can seal to. You can't drive these things around with no tank cover, or even a cover that is not completely sealed to the side rails and bulkhead, as exhaust gasses seep inside (ask me how I know ).
          The first pic is from an Eric Gill article in the RESTORER, winter 1982. Probably a GM photo of a pilot Z06 tanker, which clearly shows the bond filling.
          So ... is the Mecum car so early that they hadn't thought of the bond, or .... is the car being auctioned without its original rear bulkhead ?
            • 15706
            My '63 AIM Sect. Z06 Sheet 3.00 (redrawn and revised 4-4-62, so it was currect at start of '63 produciton) has a "fill with bond" note pointing to those depressions, and the depressions are crosshatched to indicate the fill area.
            So this raises some suspicion.
            • James G.
              • May 31, 1976
              • 1556
              Hi Wayne,
              If you look close it is vin # 895 not 695. Car is described here http://registryofcorvetteracecars.co...view_cars/1142
              • Martin M.
                • November 1, 1979
                • 124
                Didn't Eric Gill own several of these cars??
                Beautiful Pahrump, NV.
                No smog, no rain, no winter, no hurricanes, no tornadoes,
                no earthquakes, no forest fires, but prime rib 24/7, and an NHL hockey team in LV.
                vetteheads.com alumni, Boston MA alumni
                1963 NOM Split, 1963 Orig Split 340, 1963 Red Vert Ex NCM opening display car
                1970 Coupe, 1985 Coupe Road Warrior, 1986 Vert
                1932 Ford Highboy Roadster TPI, 1932 Chev 4 Dr Confederate Sedan
                1957 Chrysler 300 C 392 Hemi Car
                All for sale - most not cheap!!!
                • Loren L.
                  • April 30, 1976
                  • 4104
                  While I have no idea what else Eric owns in the way of ZO6s, at one time he did own the body of the dark blue Grady Davis' ZO6, the body having been replaced after an accident in the interests of $$$ common sense by a body shop; this led to litigation with Leon Hurd, the initial 2nd Owner, who had chased down the car much later in life and re-acquired it (minus the original body, as it turned out); I believe the car is currently the property of the NCM. Eric was perhaps the LEADING chronicler (sp?) of the ZO6s and his imprint can be found everywhere.
                  • Joe R.
                    • July 31, 1976
                    • 4551
                    Eric, at one time owned the Green Chevrolet ZO-6! It was acquired from my friend Mike Pillsbury as Mike delivered it to Eric at Cypress Gardens several years ago. I had the opportunity to inspect and photograph this original ZO-6. It was a lovely green color that I'm sure was applied by GM at St. Louis. At least it was original Lacquer!!! RIP Mike!
                    JR
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Originally posted by James Gessner (943)
                      Hi Wayne,
                      Jim -- right you are ! There were so many VIN #s being discussed on that Madison Avenue (Mecum) write-up that I even forgot what car it was they were going to auction.
                      Checked my old files and I had Z06 #895 listed as early as January 1985.
                        • 15706
                        JR
                        The Alan Green Z-06 was originally Ermine White. I watched Jerry Grant drive it at the Seafair Races at Kent, four months after I bought my SWC from Alan Green Chevrolet. (Don Campbell, Jerry's co-driver at Sebring in March '63, was my salesman.)
                        From the standing start of the big bore production race, he was the first to storm into Turn 1, flat out, where I was situated, but he was a DNF. The FI pump drive cable broke about halfway through the race!
