Does anyone have this lift or have a valid opinion on this lift. It would be perfect for my garage. It appears to be certified. Thanks
Opinion on this car lift
Re: Opinion on this car lift
Larry,Looks like a nice solution. With a resting height of about 5", your C1 should be able to go over it. I also have a C5 and C2 and the C2 will make it over and the C5 will not. What is the price of the lift?Jerry- Top
http://www.mohawklifts.com/wp/consum...ifts/usl-6000/
Has a scissor lift for years. Sold it and installed a four post. Four post is good for storage. Not great for working on suspension etc.
As for clearance I installed 2-2x10 on each side of the scissor lift. That provided enough clearance for a C5.- Top
Bend Pak MD-6XP, but you can find others like Eagle lift PMR-6000
Not too pricy. Once the car in over it you don't even know it is in the garage.
You can do nearly everything you need except may tranny work. You can access to the gear shifter and drain/refill if needed.
Sold my scissor lift for a four post. Miss the scissor lift every time I need to work any of my cars. Life was better with the scissor lift.- Top
Larry I was at the convention and only looked today at the board . I am a Mohawk distributor and have owned a USL6000 for over 10 years. We pulled a motor and tranny from a 59 we are restoring on the lift It will give you 6 feet underneath and the center is open to any repair needed. The Bend Pac and the other lifts mentioned are platform lifts, taking up much more space under the car and they have to be bolted down The Mohawk lift uses swing arms and comes with stackable height adapters. The other nice feature is the Mohawk is portable and can be moved if necessary. we moved ours outside to power wash the bottom of the 59. If you have any questions send me a e-mail
Mark- Top
Mark, Can you send me pictures and specs to make the wood ramps for the USL6000? My email is: jtranger@pacbell.net. Thanks, Larry- Top
Not to hijack this thread but has anyone bought a Stinger lift that is advertised in the Driveline? THANKS65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Mark,
Can you leave a car raised on the USL6000 for an extended length of time? If the lift can be used to lift the vehicle to be worked on but also to leave it up would it allow you to drive a portion of another car underneath the raised vehicle to manage space constraints? A platform lift would be best but that takes up to much space in my garage.
SamSam Gallagher
Savannah, GA
NCRS #58549
1964 Coupe Fuelie (2x 2nd Flight Awards)
1990 ZR1 McLellan Mark of Excellence and Cross Flight Awards- Top
Sam the answer to your question is yes You can leave a car in the air All brands of scissor lifts have a locking system. As with any style lift ,when raised the lift should always be parked on the mechanical locks for safety.
There is not very much room when a scissor lift is raised for pulling a car underneath but there is a few feet available.
Mark- Top
