B28 Vacuum Advance Control - NCRS Discussion Boards
  • Doug R.
    • November 2, 2009
    • 65
    I am in need of a B28 (236-16) VAC.I have a 327/365 and have the wrong unit on it now.Does anyone have a reliable source to purchase an in spec.(4"hg.-8"hg.)unit.I am trying to solve a overheating problem and a correctly functioning unit is a must. Thanks Doug
  • Leif A.
    • August 31, 1997
    • 3657
    Re: B28 Vacuum Advance Control
    LIC...part #48-16B.
    Leif
    • Peter S.
      • March 28, 2012
      • 327
      Hey Doug,
      I recently saw one in an ad over on the corvette forum.
      http://forums.corvetteforum.com/c3-p...rts-parts.html
        • April 1, 2000
        • 477
        Airtex / Wells #4v1053 at rockauto.com for about $5. Local parts store near you probably has one also.
        I saved a CF post by John Hinckley which had the following cross-reference numbers:
        GM #88924985
        AC-Delco #D1312C
        Airtex #4V1053
        BWD #V329
        Standard #VC-177
        Wells #DV1810
        Niehoff #DR-305
        I suspect like some parts today, that there may be a lot of re-branding of the exact same commonly manufactured part.
        • Jim T.
          • March 1, 1993
          • 5351
          Doug I made a note from reading a post that AIRTEX 4V1053 is the B28. I have a B28 that I bought at my local NAPA, it is in a NAPA ECHLIN marked box and is a VC1810. Do not know if it is still available at NAPA.
          • Doug R.
            • November 2, 2009
            • 65
            Thanks to everyone, has anyone tested the ones they have bought for accuracy? Doug
            • Patrick B.
              • August 31, 1985
              • 2017
              Yes, I bought the airtex 4V1053 from Rock Auto (marked B28) and it tested on spec (4"-8") with a Mighty-Vac.
              • Doug R.
                • November 2, 2009
                • 65
                Jack and Patrick, Thanks very much I ordered one from Rock Auto, Hope I get a spec one! Thanks Doug
                  • 15706
                  Originally posted by Leif Anderson (29632)
                  LIC...part #48-16B.
                  You have to be very careful when buying a "reproduction" MS 236-16 VAC. Many have the correct OE GM numbers, but are really "B1" VACs that don't provide full advance until about 19". These don't even meet the Two-Inch-Rule for a base engine with manual transmission. They are boat anchors!
                  It's best to buy a B28, all of which are made by Standard Motor Products... or at least they used to because they appear to be getting hard to find.
                  Post #4 has the part numbers for some available brands, but the part inside the box, as long as it's stamped B28, is the same SMP-manufactured part regardless of the name on the box.
                  Here's a thread where someone found a B28 in the Airtex brand:
                  https://www.forums.ncrs.org/showthre...ight=rock+auto
                  Before installing I recommend testing the VAC with a Mighty Vac to verify that it's reasonably in spec, and once on the engine it should be tested to verify that the maximum advance is within spec. Figure within +/- one inch Hg and a degree or two of published nominal specs.
                  • Jeff C.
                    • September 30, 1997
                    • 233
                    www.rockauto.com Part # 4v1053 price $5.15. I bought 2 in Nov 2013. I checked it with a mighty-vac also. It was on spec.
                    Jeff
                    • Michael J.
                      • January 27, 2009
                      • 7175
                      I have one on my '64 L76, runs like a scalded dog and never heats either.
