How to remove wire on inside of generator positive stud - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    I'm rebuilding my 58 generator and want to replace the studs where the wires connects. The negative stud has a screw that connects to the brush. Looks like the positive is soldered but was unable to get it loose with a soldering iron. Is the wire crimped or is it soldered?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11363
    Re: How to remove wire on inside of generator positive stud
    Brandon,
    What wattage rating is the iron? You need a high power iron, or a large soldering gun. It takes a lot of heat to get that stud hot enough to flow solder. You could use a small fine tip torch to preheat the stud then switch to the gun for the wire connection.
    I did this stud for a generator with a Weller gun....
    I think these stud wires were originally arc welded as it was a quicker way to do the job, as opposed to waiting for the mass to heat with conventional soldering.
    Rich
    • Brandon T.
      • October 23, 2008
      • 872
      Thanks Rich, I have a weller gun that is a higher wattage. I will try using it when I get home tonight.
      • Brandon T.
        • October 23, 2008
        • 872
        Rich, I got my wire off and got it soldered back. The higher wattage iron did the trick. Thanks for the help.
