'61 FI Dipstick Tube Orientation - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    My Dipstick tube is pointing toward the steering wheel and is pressed up tight against my air box. I know this can't be right. Is there a special tube I can order for an FI or do I have to custom bend it? Attached is a photo. Thanks.
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    Re: '61 FI Dipstick Tube Orientation
    There is no special tube or bend for the FI cars. Instruction per AIM is "Install tube with plane of bend parallel to center line of crankshaft." Hope this helps.
    • Larry B.
      • October 21, 2010
      • 254
      I have seen pictures of FI cars with the tube bent straight up parallel to the exhaust manifold.
      • Bill B.
        • December 1, 1993
        • 192
        Mine is turned at base towards firewall enough to clear filter assembly. You did say air box, I am a little confused thought air box was one year only offered in 1957 model year special order for racing only? Can you please send pictures?
        Bill
        1961 Corvette Fuel Injection 283 cid. 315 hp, Tuxedo Black/Sateen Silver/Roman Red
        "The problem with Liberalism is that eventually you run out of other people's money" Margaret Thatcher
        • Larry B.
          • October 21, 2010
          • 254
          Bill,
          I meant filter assembly. Dot you have a photo of yours? My photo is in the first post. Mine is very tight and rubs up on my cleaner assembly.
          Larry
          • Bill B.
            • December 1, 1993
            • 192
            Yes, my dipstick is very close to cleaner assembly as well. Was thinking you may have a COPO, always looking for a diamond in the ruff. Bill
            • Larry B.
              • October 21, 2010
              • 254
              I wish Bill!
