DOT tire coding - NCRS Discussion Boards
DOT tire coding
+ More Options
Posts
    • 15706
    DOT tire coding
    Thought I'd start a new thread as a follow-up to Gary's question from earlier this morning. I knew I had something at the bottom of my tire file that explained the coding. It is a sheet from a retail tire catalog that dates back to probably about the mid-seventies - page 55, yellow paper, about 8.5" by 5.5" sheet size. I should have written down the vendor and
    date, but didn't. I believe it might be a Dav-Mac catalog, and I don't think they are in business anymore.
    In any event, it gives an example and says this coding method applies to all tires manufacturered for sale in the US after May 21, 1971.
    MAL9ABC032
    MA - Manufacturer and plant code
    L9 - Tire size code
    ABC - Group of symbols optional with the manufacturer.
    032 - date code, week (1-52) and last digit of the year.
    I believe this coding system is still current, except, beginning circa 2000 the date code is four digits, the last two being the last two digits of the year so the decade is indentified.
    As far as trying to find out the specfics of the coding beyond the date code,I have no idea where to start, except to try to find someone at the manufactuer knowledgeable to intrepret the plant, size, and optional codes.
  • David N.
    • June 30, 1991
    • 142
    Re: DOT tire coding
    Duke, If my memory serves me correctly, tire DOT tire coding is available in the SAE Handbooks. Many libraries carry them in the reference files. You should be able to find the data there.
    Good Luck,
    David Nims 19639
    • Robert C.
      • December 1, 1993
      • 1153
      Re: DOT tire coding
      Thanks Duke, The info for tire dates after 71 are as you show, it's the codes before 71 May that are the problem. These codes, without a code book are impossible to figure out.
