More Cams - NCRS Discussion Boards
More Cams
  • Tom H.
    • September 30, 2002
    • 136
    More Cams
    What is the current equivalent for the the 30-30 cam in the 65 SHP small block. Also what is the lash for the "replacement" cam.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: More Cams
    i can not find any replacement cam for the 30/30. i think the 097 replacement cam is still available
    • William C.
      • May 31, 1975
      • 6037
      Re: More Cams
      You have several options, ranging from an exact duplicate of the GM cam from an aftermarket source like TRW or Mellings, to using the LT-1 cam from GM, to using a more modern custom design from an outfit like Competition cams. Search the archives, as thid topic has been discussed in depth in the last year. Each approach has it's own advantages and disadvantages, so the best course is to inform youself of the tradeoffs discussed and make the choice that is best for your desured use.
      Bill Clupper #618
        • 15690
        Re: More Cams
        The 30-30 was discontinued in the early to mid seventies and the LT-1 cam was listed as a replacement for all 30-30 applications, which were the 64-65 SHP/FI engines and all 302 CID Z-28s. Interestingly, the Duntov cam
        continued to be offered long after the 30-30 was gone.
        I think this is a tacit admission that the 30-30 was a "mistake". I don't know if any of these cams are available from GMPD. You can check with a dealer
        and also look at the GM Performance Parts Catalog as clones are probably
        offered, but they are probably purchased from the outside. Also, Federal
        Mogul and some of the aftermarket cam grinders offer clones.
        I recommend the LT-1 cam for ALL mechanical lifter engine rebuilds.
        • Joe C.
          • August 31, 1999
          • 4598
          Re: More Cams
          Tom:
          An exact duplicate of the 30-30 is available from Fereral Mogul's Sealed Power line of engine parts. It is listed as part number CS118R in their performance parts catalog.
          The 30-30 cam is also available from Crane, as "Blueprinted 3849346".
          The LT1 cam is available from Crane, as "Blueprinted 3972178".
          The lash for the 30-30 is specified as .030" int., .030" exh.
          The lash for the LT1 is specified as .024" int., .030" exh.
          Joe
          • Clem Z.
            • January 1, 2006
            • 9427
            Re: More Cams
            joe is correct as it is also available from GM performance parts as a kit,cam and lifters,part #12364052 but your compression ratio should be 11:1 or better. i was looking for the wrong orignal part number,i got to stop trusting my memory.
            • Tom H.
              • 136
              Re: More Cams
              Thanks to all who responded- Your collective help is greatly appreciated.
