69 Expansion Tank - NCRS Discussion Boards
69 Expansion Tank
  • jack 35268
    69 Expansion Tank
    The tank was missing. I ordered and received a new expansion tank. It has two pipes from the bottom for heater "type" hose size. Is this the correct tank? If so, Which hoses hook-up here? jackdr
    • 43203
    Re: 69 Expansion Tank
    Jack-----
    The tank is the correct tank if it has the number "3016340" on the end of it (assuming that you don't have a big block with A/C).
    The 3/4" heater hose from the water pump goes to the tank "front" nipple and the tank "rear" nipple then goes to the 3/4" fitting on the heater core.
    • jack 35268
      Joe, You assumed correctly (350). I have the NCRS, 3rd. addition but I loaned it out so have no other reference at the time. This helps. Thanks, jackdr
