I'm ready to install some new inner fender dust seals that go between the top of the inner fender and the underside of the upper surround on my '66. There is a front and rear seal on both sides. Were these seals trimmed at the apex of the inner fender (where it forms a point) so that the material didn't "bunch up" or were they installed as one continuous piece? Neither the AIM nor the archives provides any clarification.
C2 inner fender seals
Re: C2 inner fender seals
They are one continuous piece stapled onto the innerfender. The interesting thing is that there are little ridges on the rubber, and they are assembled either with the ridges to the inside of the wheel well or to the outside, but not one in and one out. There can be as few as 6 staples up to 14 or so, most having 7-9 staples.- Top
The staples were installed by a machine that had a spring steel wire spool, that cut and bent and crimped the staple all at the same time. The operator most likely had a foot pedal or something like that to activate it. He would stand holding the innerfender over the die, or anvil part with the other end hanging below. This means that all staples are from outside with an inside the wheel well crimp. They didnt really give a rat`s about symetry actually. The roll of rubber was hanging there and thats the way it came off the roll. So one or the other ribbed or not was always out. I have seen all out or all in depending on how the roll was mounted. The amount of staples depended on the operator.- Top
