Ignition Shielding for '71 LS5 - NCRS Discussion Boards
  • MIke G #33811
    My ignition shielding needs to be rechromed from my '71 LS5. How can you rechrome the part and still retain the original look with the plastic rivets? Can the rivets be reinstalled after removal? How is this handled?
    Thanks.
  • Juliet P.
    • June 30, 1999
    • 349
    I had to repair one once....
    I'm not sure of the *proper* procedure, but I accidentally snapped one of my original plastic rivets out of my original '70 lid one day while trying to polish off some of the corrosion on the inside of the ignition shielding. I found the top (only after considerable time spent examining the garage floor on my hands and knees) and epoxied it back to the other half of the plastic rivet. It's been a while (and the garage is too damn cold to go look inside now) but I think there was a little washer in there too on the outside of the plastic piece. So far so good in terms of it holding together... its been almost a year and 4000 miles since I repaired it. I think though that the '71 shielding is different from the early '70 shielding so you might have different rivet / washer / plastic liner setup than I did. If I recall correctly that all changed around S/N 12000 in 1970 when they went to the dual snorkel closed element air filter. ~Juliet
    Join the '70 Corvette Registry
    2019 Sebring Orange 8-Spd Coupe (daily driver & autocross) 6k mi.
    1970 Bridgehampton Blue Convertible - Chapter Top Flight 2005 68k mi.
    1965 Coupe (Greg's project No Flight)
    Gone but not forgotten:
    1987 Yellow Convertible 199k mi.
    2002 Yellow Convertible 100k mi.
    2007 Atomic Orange Coupe 140k mi. RIP flood 2015
    2007 Lemans Blue 6-Spd Coupe 34k mi.
    • Dave S.
      • August 31, 1992
      • 2926
      Re: Ignition Shielding for '71 LS5
      I don't think you can remove and replace the rivets without causing some problems. Those pieces are available in nice condition(with original flash chrome) from Corvette parts vendors or at swap meets. I think that would be the best route to take
