63 cam and pistons - NCRS Discussion Boards
63 cam and pistons
  • Steve D.
    • February 1, 2002
    • 990
    63 cam and pistons
    The engine in my 63 is a very NOM_ 65 block, 67 heads, 62 distributor. I have the engine on a stand now, and I am trying to identify the cam and pistons.
    Cam
    Stamped in distributor end__ 760 CR 11 49-97
    In a smaller font and very feintly stamped 183920 (last digit questionable)
    On shaft on either side of distributor gear, raised_ C9 CWC on one side and D9 1539 on the other side.
    On shaft at front end, 10 67
    Pistons
    Stamped in top of each piston _ 040 L2166N
    Pistons are still in block and I could see no other #'s. I know that the 040 signifies 40/1000 overbore.
    The engine was apparently rebuilt fairly recently, as the galley plugs still have some shine on them.
    Is this enough information to identify either or both?
    Steve
    • 15692
    Re: 63 cam and pistons
    Pistons are Federal Mogul Speed Pro (nee TRW) eighth-inch dome forged pieces, which are essentially OEM replacements.
    The cam is likely aftermarket, but I can't identify it.
    • Steve D.
      • February 1, 2002
      • 990
      Thanx.
      I have read that pistons were one of the differences between the 300 and 340. Is this replacement for 300 or 340?
      Steve
      • Clem Z.
        • January 1, 2006
        • 9427
        if the piston reads, L-2166NF they are forged as i can not find L-2166N listed. F/M list a cam # CS1149R which has .245 in and .265 ex lift at the lobe,184/194 dur at .050 lift, 258/268 dur at .006 lift, 104 degress lobe center
        • Clem Z.
          • January 1, 2006
          • 9427
          PS
          the cam is hyd not solid lifter design
            • 15692
            Those are the forged, domed SHP/FI pistons - correct for a '63 L-76.
            • Steve D.
              • February 1, 2002
              • 990
              Re: PS
              Clem
              Thanks.
              I forgot to note that my engine has hydraulic lifters.
              How would you characterize the F/M cam that you listed the specs for? Is it close to a replacement for the OEM 300 set up?
              Steve
