'66 power steering help - NCRS Discussion Boards
  • Allen Zubatkin
    Got a strange problem that I am not sure how to remedy: Just reinstalled the system, and bled it according to the documented GM sequence.
    It seems that there is air in the system even after 2 attempts. Not only that but the wheel violently jerks to the left when the engine is started, then it jerks violently back and forth until the engine is shut down.
    What is going on??!!
    Thanks in advance,
    Allen
    • 43236
    Re: '66 power steering help
    Allen-----
    My guess: the centering adjustment on your p/s control valve is way off.
      • 43236
      Allen-----
      • Allen Zubatkin
        Joe,
        That is what we originally thought, but even when we adjust the screw it still does it......could it need a rebuild?
        Allen
        • Allen Zubatkin
          Joe,
          Allen
            • 43236
            Allen------
            These valves can be VERY difficult to get adjusted correctly without doing it "off-car" on a test bench (which very few folks have access to). I doubt that a rebuild will solve this problem, but, I suppose, it's worth a shot.
              • 43236
              Allen------
              • Allen Zubatkin
                I was afraid that was what you were going to say.....hmmm, perhaps a 'new' one is in order here....
                • Allen Zubatkin
                  • Wayne W.
                    • April 30, 1982
                    • 3605
                    The hoses are on wrong. They cross.
                    • Wayne W.
                      • April 30, 1982
                      • 3605
                      • Allen Zubatkin
                        Excuse me....do you mean we hooked it up wrong? Hmmm...
                        • Allen Zubatkin
                          • Wayne W.
                            • April 30, 1982
                            • 3605
                            The two hoses from the valve to the cylinder cross. It is common for people to install them wrong.
                            • Wayne W.
                              • April 30, 1982
                              • 3605
