Rear wheel bearing setup - NCRS Discussion Boards
  • Scott Marshall
    My question is about installing rear wheel bearing on a 72. Do the rear wheel bearings need to be packed before using the setup tool or does it matter.
    • 15696
    Re: Rear wheel bearing setup
    Grease should not affect the end play, but it's pretty messy, so do the fit with just a thin film of grease on the races.
    Once they're installed with grease for the final check, rotate the spindle several times while pushing it in and out. This should force excess grease from the bearings and allow you to measure the true end play.
      • 15696
      • andy#34338
        Scott,
        I just did the bearings on my C1 and used sealed bearings. Do they not have sealed for your application? You may want to look into it.
        Andy
        • andy#34338
          Scott,
          Andy
            Andy -
            You may want to take another look at the "sealed" 607 bearings (most likely from BCA) in your C-1; the bearings now being supplied as replacements were designed for use in lathes and other machine tools, and just happen to "fit" C1 Corvettes. In order for them to last, the "seal" on the inboard side of the bearing needs to be removed so it can get lube from the diff, or they will eventually fail; the seal removed from the inboard side must then be re-installed on the outboard side (or use new seals) to keep lube off the brakes. Those bearings NEED lube.
              Andy -
              • andy#34338
                They had seals on both sides
                John,
                I did not keep the box they cam in. I will look into it and let you know. The bearings I installed were sealed on both sides. I have about 15 hours on them, mostly highway at 70 MPH or better and have seen no indication of problems. I was under the rear replacing the rubber for the sway bar yesterday and inspected everything associated with the rear. I replaced the bearings because I installed a posi and have been keeping a close eye the rear and assocoated parts. One of the old bearings was installed backwords, no telling how many hours were on those bearings.
                • andy#34338
                  John,
                  • andy#34338
                    John, Called Federal Mogul tech line 800-325-8885
                    John,
                    I called Federal Mogul tech line and they verified that these are "sealed" bearings that do not need external lubrication. The darn things were $100 each. I figured they were so darn expensive because they were sealed. These also had 2 O-rings on the OD. They looked like nice parts.
                    Please, if you can, give me more info on this issue. My email is awilco@hotmail.com
                    Andy Wilcox
                    • andy#34338
                      John,
                      Andy Wilcox
                      • Al C.
                        • July 31, 1999
                        • 274
                        Re: John, Called Federal Mogul tech line 800-325-8
                        Andy, for future reference, what is the part number of those Federal Mogul bearings?
                        ... Al '58 #378 245hp NCRS SACC
                        • Al C.
                          • July 31, 1999
                          • 274
                          • andy#34338
                            Bearing # is BCA RW 607 NR
                            Al,
                            Federal Mogul owns BCA . BCA/Federal Mogul swears the bearing is sealed on both sides and not to remove the seal but I tend to believe John more.
                            Andy
                            • andy#34338
                              Al,
                              Andy
