Bolt for holding fuel pump push rod - NCRS Discussion Boards
    • September 30, 1999
    • 710
    The bolt replaces the one that holds the fuel pump rod in place, should it have a washer on it, what stops oil from dripping out? I know there is no pressure there so would some permatex #2 would help? Also what lenght should it be. I have a 3/8x1/2 in there now and dosen't appear to bottom out on anything. Thanks Mike
  • ERIC FAIRCLO
    Re: Bolt for holding fuel pump push rod
    I have never used any sealant and never had any leaks on several cars. I think mine is 3/8 by 1/2. Mine always tighned down. Permatex would'nt hurt.
    • ERIC FAIRCLO
        • 43221
        Mike-----
        There's not supposed to be any washer on this bolt. 1/2" length is fine. Use Permatex on it to insure a seal. Otherwise, you may get oil "creep" past the threads---not a serious leak, but just enough to "mess up" the front of your engine.
          • 43221
          Mike-----
