77 GEARS - NCRS Discussion Boards
77 GEARS
  • CHRIS HUBER
    77 GEARS
    MY 77 L-48 RUNS ABOUT 2400 RPMS AT 60 MPH. COULD ANYONE TELL ME WHAT KIND OF REAREND I HAVE IN MY SHARK BASED ON THIS INFO? AND IF SO, DO YOU THINK IT IS STOCK.
    THANKS,
    CHRIS
    P.S- JOE L. DID YOU RECIEVE MY BOGUS E-MAIL ABOUT FENDER FLARES :0)
  • Russell Fulks
    Re: 77 GEARS
    Based on Dukes earlier post to my 77's transmission, based on factory wheel size, ~760 revolutions/mile, the ratio would be:
    ratio = rpm@60mph / 760rev/mile = ~3.15
    Russ Fulks
    • Russell Fulks
      Re: 77 GEARS
      Russ Fulks
      • Grant M.
        • August 31, 1995
        • 448
        Re: 77 GEARS
        I don't know if there was a 3.15 offered, but I believe that 3.08 was the optional 'highway' ratio. probably close enough to assume that's what you've got if it's stock.
        • Grant M.
          • August 31, 1995
          • 448
          Re: 77 GEARS
          • Russell Fulks
            Re: 77 GEARS
            I just opened up my owners manual and voila! 3.08 rear end is probably what you have. If you don't trust your tach or speedo you can do the following:
            Raise the rear wheels, release the parking brake. Spin the rear wheels by hand counting how many times the drive axle rotates to complete 1 rotation of the wheel. The number of drive axle rotations is your rear differential ratio!
            I just did mine today -3.70:1
            Russ
            • Russell Fulks
              Re: 77 GEARS
              Russ
                • 15684
                Re: 77 GEARS
                It's tough to read a speedo or tach to one or two percent accuracy and the instruments themselves are probaby no better than within two percent of true at best.
                It's a 3.08, and Chris, in the future would you please post in normal lower case type.
                  • 15684
                  Re: 77 GEARS
