70 LT1 stamped CTK on pad - NCRS Discussion Boards
  • David Bolderson
    Can anyone give me an explanation why I have a CTK stamped on front pad and a casting number which reads 3970020? Did a Corvette motor ever have this 020 stamp?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 70 LT1 stamped CTK on pad
    here is what i found CTK,1974 400 ci caprice, also 1978 305 used in F and X body, 3970020 1970/73 307 ci your guess is as good as mine. most 400 blocks have 3 soft plugs on the side of the block,some have only 2 plugs but have a place for the third one.
    • Clem Z.
      • January 1, 2006
      • 9427
      • Tom Freeman
        Sorry for the deleted posts
        Sorry for the deleted posts but I had totaly missread the question.
        tom...
        • Tom Freeman
          tom...
            • 43260
            David-----
            3970020 is a 307 cid block. As far as I know, no Corvettes ever used this block. I don't think that GM would ever have used this block for a 350 cid configuration. To do so would have involved using a bore size that the block was never designed for. In the field, someone might attempt such an overbore, but I don't think that GM would ever have used it in PRODUCTION.
              • 43260
              David-----
              • Robert C.
                • December 1, 1993
                • 1153
                Joe, in 1980 Corvette had engine code ZCA, 305ci.180hp, option # LG4(Calif.cars)
                • Robert C.
                  • December 1, 1993
                  • 1153
                    • 43260
                    Bob-----
                    Yes, however the 307 and 305 cid engines have completely different bore and stroke configurations and utilize different blocks. The 307 cid engine of 1970-73 vintage utilized a 283 bore (3.875") and a 327 stroke (3.25") to produce a cid of 307. The much later 305 cid engines used a smaller bore of 3.74" in combination with a 350 stroke (3.48") to produce its 305 cid displacement.
                      • 43260
                      Bob-----
