Car Cover Washing??? - NCRS Discussion Boards
  • Jeff Chester
    This may be a simple answer to many, yet i don't do laundry...
    My C5 cover needs cleaned, were do i take it, it is very large...
    will this fir in a normal clothes washer or must it go to an industrial one?
    Jeff (not so smart)chester
    • 43222
    Re: Car Cover Washing???
    Jeff-----
    It depends what kind of a cover that it is. If it's a cotton, poly/cotten or cotton with flannel backing, they can usually be washed in a home-type clothes washer. However, it needs to be done on "extra large" load setting and with NO other items in the wash.
    If you have a cover of other material (like Evolution 4 or Noah), those are not really made to be washed in a washing machine. The manufacturers NOW say that they can be so-washed (they used to say DON'T wash them in a washing machine), but it's usually way down in the "fine print" and they seem very "lukewarm" about the idea. Personally, I wouldn't attempt it. But, if one does try it, the bulky nature of these type covers will make a commercial washer an absolute necessity. I'm not even sure if one of those of the type found in most laundromats would do the job.
      • 43222
      Jeff-----
      • Gary B.
        • February 1, 1997
        • 7024
        Evolution 4 Washing
        Jeff,
        I've washed my Evolution 4 cover at a coin operated laundramat. You should use the largest machine they have, which will cost $4 or $5 per load. Most places have 3 or 4 of the very large machines and 15 or 20 of the smaller ones that cost only $1.25 or so. Don't use the smaller machines. I recommend air drying, as I destroyed one cover the only time I tried using a machine dryer.
        Gary
        • Gary B.
          • February 1, 1997
          • 7024
          Evolution 4 Washing
          Jeff,
          Gary
          • Jeff Chester
            Re: Washing
            I don't know what type I have, It cost about 149.00.
            thanks for the drying tip, for washing I mainly want to get the.....
            .... tire rubber...off the rear... and where the back draft on the C5 puts dust on the rear taillight section...and the #@&%/*& cat paw prints...
            ...anybody have a shovel????
            thanks,
            jc
            • Jeff Chester
              Re: Washing
              thanks,
              jc
                • 15680
                Re: Washing
                If it's a single layer cover either an older cotton or cotton poly or one of the newer thin single layer "weathergard" type covers it can probably be washed in a home washer. If it's a thick mulitlayer Evolution type cover (bulky) then it must go to one of those big tumble washers in a laudromat. I usually go to a laundromat and wash several covers in one load.
                In any event, as stated previously, DO NOT DRY the cover in a dryer. Just put it on the freshly washed car, and let it air dry.
                Also, use very little soap - about a quarter of what you would use in the specific washer for a normal load.
                If you still have the data sheet for your cover, it should have washing and drying instructions.
                  • 15680
                  Re: Washing
                  • Grant M.
                    • August 31, 1995
                    • 448
                    Re: Washing
                    Duke,
                    Good advice about not using the dryer. I washed my cotton flannel cover last year, and even with the dryer on low heat, I got significant shrinkage. it still fits the car and seems to be stretching a little over time, but it's not a long on the sides as it used to be, leaving some wheel and rocker panel exposed.
                    grant
                    • Grant M.
                      • August 31, 1995
                      • 448
                      Re: Washing
                      Duke,
                      grant
                      • Jim T.
                        • March 1, 1993
                        • 5351
                        Re: Washing
                        The washing instructions with the evolution covers I have bought said to use Fantastic as a cleaner and to use the big commercial washer and air dry.
                        • Jim T.
                          • March 1, 1993
                          • 5351
                          Re: Washing
