65 327/350 heads HT Continues - NCRS Discussion Boards
  • Jimmy Roggenbuck
    I have pulled the heads and took them to machine shop and he thinks it was the head gasket but will flux and checkfor cracks. I took both down and now I have questions on gasket.
    The head gasket was a older thin metal gasket I have seen different opinions on gasket types and would like some feedback on what would be reliable and long lasting.
    If I had leakage of rad. fluid into the cylinders does that meen engine block will need to be reworked/ rings?
    My last question in the top of the valve covers was a "gel" like substance that was on both sides. Someone mentioned antifreeze and oil mixed makes this gel I did just change my oil and did not notice any antifreeze any ideas much appreciated thanks to all
  • Wayne C.
    • November 1, 1978
    • 289
    Re: 65 327/350 heads HT Continues
    In the past I've seen posts recommending Fel-Pro "Perma Torque" composition gaskets.
    • Wayne C.
      • November 1, 1978
      • 289
        • 43237
        Wayne and Jimmy------
        They're always my choice. For your engine, the Fel-Pro number is 1003. They're not inexpensive, though----about 40 bucks/each from discount sources and they're packaged in a quantity of ONE.
        Stock, shim type gaskets will seal very well BUT the block and head surface must be absolutely true and flat.
          • 43237
          • Gene M.
            • April 1, 1985
            • 4232
            Felpro gasket points deduction
            If you go with the Felpro blue gaskets a points deduction will be made as there is a vast difference from the original stamped steel. The original stamped steel will yeild a slightly higher cylinder compression.
            • Gene M.
              • April 1, 1985
              • 4232
              • Gary B.
                • February 1, 1997
                • 7029
                Gene,
                What sort of deduction is typical? One or two points?
                Gary
                • Gary B.
                  • February 1, 1997
                  • 7029
                  Gene,
                  Gary
                    Re: Felpro gasket points deduction
                    This is another area where I choose to "take the hit" and use the Fel-Pro composition gaskets; anyone who decides to use the "correct" steel shim gaskets on old block and head surfaces and risks critical sealing failure for the sake of a couple of points needs to re-assess their goals and whether they really want to drive their car. Of course, that's just my opinion, and I could be wrong The Fel-Pros will also reduce compression about half a point, which is not a bad thing with today's fuels.
                      • Pat Bush #35083
                        Jimmy:
                        Take the points deduction and install the Felpro Perma-torque head gaskets. I have used them forever and they always are solid, great performing gaskets. Copper and Steel gaskets are fine from the factory. But there is almost always some minor warpage in the head or block after running the motor. Its not enough to normally blow a gasket but if you try to install one again, it may be enough for it not to seal well enough.
                        My 2 cents.
                        Pat
                        • Pat Bush #35083
                          Jimmy:
                          My 2 cents.
                          Pat
                            • 11651
                            Joe,
                            These gaskets are a little cheaper through Summit at $29, but for a total of $90 I went ahead and bought the whole Performance Kit from Fel-Pro (again through Summit) which includes TWO head gaskets as well as a wide assortment of the rest you'll need anyway.
                            Patrick
                              • 11651
                              Joe,
                              Patrick
