Harmonic Balancer Application - NCRS Discussion Boards
  • Dan M.
    • November 1, 2000
    • 48
    Can someone tell me the application for a 7" dia part # 3860060 HB. It looks like the bore would fit a BB crank. Could this be off a late 60's HP engine?
    Thanks in advance for your comments
    Dan
    NCRS 35068
    Dan Morlang
    • 43208
    Re: Harmonic Balancer Application
    Dan-----
    It is a big block balancer but I don't think that it was ever used for a Corvette application. I can probably tell you later what the application was.
      • 43208
      Addendum
      Dan-----
      The number that you mentioned, GM #3860060, was never the PART number for any big block balancer. However, it was the CASTING number for the hub section of the 7" OD, neutral-balanced balancer used on MANY 65-69 396 and 427 engines with hydraulic lifters, including 66-69 Corvette L-36 and L-68. The part number for this balancer is GM #3860008 and it's still available from GM. The balancer should weight 10-1/4 pounds.
