Fan clutch storage - NCRS Discussion Boards
Fan clutch storage
    Re: In the box, GM says 2 ways, depending on type
    Wayne -
    I believe that the "this side up" on the bimetallic plate on the Schwitzer clutch refers only to the plate itself; if you install the plate the other way, it'll curve in the wrong direction when heated and won't operate the internal valve.
    • John D.
      • December 1, 1979
      • 5507
      Re: Fan clutch storage
      Gary, After I wrote my note I thought the same thing as you. STORE THE Thing AS IT IS ON THE CAR. John
      • Harry Sadlock
        #18
        John, I agree. The only difference is that on the car it turns when the engine is running. So I would think that while in storage it should be rotated to circulate the fluid.
        Harry
        • Wayne M.
          • March 1, 1980
          • 6414
          #19
          You're right -- side up is for bimetallic strip
          John -- got thinking of the same thing after I'd posted. In the attached pic, you can see the bow outwards at the middle. Also note faint etch of letters 'CJ' on top edge. And always nice to know it's patented in CANADA.
          But still think that because of that little piston under the strip, to be safe, I'd store face-up.
