Fan clutch storage - NCRS Discussion Boards
Fan clutch storage
  • Mark Z.
    • March 1, 2004
    • 48
    Fan clutch storage
    How should the fan clutch be stored? Mounting hub up, down, or sideways?
  • Harry Sadlock
    Re: Fan clutch storage
    Sideways.
    • Harry Sadlock
      Sideways.
      • Gary B.
        • February 1, 1997
        • 7023
        Fan clutch storage
        I'm pretty sure that the GM fan clutch I bought recently specifically states on the box (or the clutch?) to store it horizontally with the mounting hub up.
        Gary
        • Gary B.
          • February 1, 1997
          • 7023
          Fan clutch storage
          Gary
          • James W.
            • December 1, 1990
            • 2655
            That's what Fred Olivia recommends also, mounting hub up.
            James West
            • James W.
              • December 1, 1990
              • 2655
              James West
              • Mike E.
                • February 28, 1975
                • 5138
                Does that mean I have to hang my car by the rear bumpers from the garage rafters?
                • Mike E.
                  • February 28, 1975
                  • 5138
                  • James W.
                    • December 1, 1990
                    • 2655
                    I'd like to see that!!!
                    • Harry Sadlock
                      Fred told me sideways when he mailed mine back.
                      Harry
                      • John D.
                        • December 1, 1979
                        • 5507
                        Rev Mike, We covered this detail at a seminar not to long ago. Bill Calarico was putting on a wonderful seminar about clutch fans. Bill said that the best way to store them is just like Gary said. Store them like it would be mounted on the car. This helps prevent the oil from running out. John
                        • Gary Schisler
                          John, aren't you stating just the opposite to what Gary is saying? He is saying horizontally, with the hub up but you say "mounted on the car" which is vertical. Am I missing something?
                          Gary
                          • Wayne M.
                            • March 1, 1980
                            • 6414
                            In the box, GM says 2 ways, depending on type
                            Sweitzer (bi-metallic strip) type says, ink-stamped right on the strip, "THIS SIDE UP".
                            Eaton (bimetallic coil) type has stamped on the face "STORE THIS FACE DOWN", in 2 places (at least on the later production).
                            And yes, vertical (as mounted on water pump hub) is also acceptable [and necessary], but not for long term storage, IMHO.
                            Just following instructions
                            • Edward S.
                              • December 1, 1986
                              • 514
                              Re: In the box, GM says 2 ways, depending on type
                              Wayne is correct - that's just what Oliva said at the session he ran at last years National.
