alternator - NCRS Discussion Boards
alternator
  • Sal R.
    • December 10, 2007
    • 160
    alternator
    On my 65 with 365hp it appears that the alternator is not correct the belts are off.When I measured from the nut on the front of the pulley to the back of the alternator where the bracket bolts up it measures 2.25 inches if it was 2.5 it would work .I do know that all the pulleys are now correct.Ther are no marking on the alternator appears to be new.Hope some one can help me.
  • Mike M.
    • September 30, 1999
    • 710
    Re: alternator
    Sal, My 65 350hp measures 2.5. The correct pulley is thick its 1.25 inches thick. This is for a non power steering no a.c car. There may be differences between these and my car. Mike
    • Mike M.
      • 710
      Re: alternator
      • Sal R.
        • December 10, 2007
        • 160
        Re: alternator
        Thanks Mike. I have the right pully if you measured 2.5 then I have the wrong alternator that 1/4 inch would make my belts straight.
        Thanks again
        Sal
        • Sal R.
          • December 10, 2007
          • 160
          Re: alternator
          Thanks again
          Sal
          • Mike M.
            • 710
            Re: alternator
            Sal, did you measure the pully to see how thick it is. I'm sure someone will provide part numbers for you. I don't have my books. Most times the thinner pully is the problem. I had the same problem with my car and I had the wrong pully on my alt. Good luck
            • Mike M.
              • 710
              Re: alternator
              • Sal R.
                • December 10, 2007
                • 160
                Re: alternator
                Yes Mike I just changed the pully for the correct one.It is the thicker one like you mentioned.
                Thanks for your help I'll let you know how I make out
                Sal
                • Sal R.
                  • December 10, 2007
                  • 160
                  Re: alternator
                  Sal
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    Does your '65 alt+pulley look like this ?
                    First of all, congrats on your choice of a '65 L76 -- best of the C2 small blocks (but then I'm prejudiced).
                    As Mike M. says, this pulley is just a hair under 1.25" thick measured at the outer flange edges, or 1.33" including it's inner collar, which fits flush against the fan hub. The outer diameter is 3_5/8". It's part # 3871242, used on L79 and L76 w/o C60, and on L84 fuel injected cars.
                    What's the part # and amps rating stamped on the top where your case bolts to the adjusting brace ?
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Re: Does your '65 alt+pulley look like this ?
                        And check out that BLACK stator, just like it's supposed to be! Not the caramel color like later 60's stators. (sorry, didn't mean to change the subject)
                        • Michael H.
                          • January 29, 2008
                          • 7477
                            • 43229
                            Re: alternator
                            Sal------
                            I don't see how the problem could be related to the alternator, assuming that no one has modified the case (which, should be readily apparent). Regardless of stamped part number, the "DN" series alternators should be dimensionally the same as far as mounting is concerned.
                              • 43229
                              Re: alternator
                              Sal------
