70 date codes - NCRS Discussion Boards
70 date codes
  • Mike G.
    • July 31, 2002
    • 709
    70 date codes
    pulled some more parts off the 70 to restore them. where is the date code on the wiper motor?
    does the horn relay have a date code? i lightly blasted the crud off of it and cant find a date. i found some numbers but dont think they are dates.
    same problem with the ti module. no date. i found the part number. this part is rough. i have a nos ti module that i can use if no date code is needed.
    thanks, mike
    • 15606
    Re: 70 date codes
    Wiper motor -- date code is on the plastic tag that is glued to the motor. If your motor doesn't have one, a reproduction is available.
    No date code on the horn relay
    I believe there is a date code on the TI amplifier, but it is not judged. Often one can not even see the TI amplifier during judging, so looking for a date code is a waste of time for the judge.
    • Mike G.
      • July 31, 2002
      • 709
      Re: 70 date codes
      wiper motor is a dirt clod. i will look closer when i get home today. i dont remember seing a plastic tag. good to know about the ti amp. i will just use the nos one with the same part number. and with a nice coat of black semi the relay will be fine.
      thanks
      • Chuck S.
        • April 1, 1992
        • 4668
        Re: 70 date codes
        The wiper motor date code will appear as an rectangular aluminum foil tag with black printing; as I recall, it should be on the barrel of the wiper motor housing.
        • Mike G.
          • July 31, 2002
          • 709
          Re: 70 date codes
          i am afraid its gone. i dont remember it having one. i will look again today. i hope i can just clean this up and use it. if it does not work i will send it off for repair / restoration.
          • tom444634
            Re: 70 date codes
            Mike,
            Picture of tag / label from my sept 70 build 71 LS5
            Tom
            • Mike G.
              • July 31, 2002
              • 709
              Re: 70 date codes
              mine has that sticker. the top number is the same but the bottom number is different. the bottom number is 111 02A. my 70 is a june 70 car. what does this date code mean?
              • Chuck S.
                • April 1, 1992
                • 4668
                Re: 70 date codes
                The first number is the same because it's the wiper motor part number. The second line includes a Julian type date, 111th day of 1970. I calculate April 21, 1970, a Tuesday.
                • Chuck S.
                  • April 1, 1992
                  • 4668
                  Re: 70 date codes
                  • Warren F.
                    • December 1, 1987
                    • 1516
                    Re: 70 date codes
                    Mike,
                    The back side of the TI amplifier does have an ink stamp. An example would be 1 A 27, this is on one of my '71 coupes. January 27, 1971
                    • Warren F.
                      • December 1, 1987
                      • 1516
                      Re: 70 date codes
                      Mike,
                      • Mike G.
                        • July 31, 2002
                        • 709
                        Re: 70 date codes
                        if its an ink stamp on the ti amp its long gone on mine. the bottom is rust and the rest is rough, real rough. i have a nos piece i can use. it looks like 68 up ti amps are the same.
                        • Mike G.
                          • July 31, 2002
                          • 709
                          Re: 70 date codes
                          • Warren F.
                            • December 1, 1987
                            • 1516
                            Re: 70 date codes
                            I have a couple of NOS 1111543 amplifiers. They also have an ink stamp. I believe Dave Fiedler at TI specialties has the proper ink stamp font for re-applying on the bottom amplier plates.
                            • Warren F.
                              • December 1, 1987
                              • 1516
                              Re: 70 date codes
