67' VENT/WINDOW GLASS MOUNTING TO FRAME - NCRS Discussion Boards
  • Jerry A.
    • May 31, 1997
    • 122
    I am in the process of restoring my 67'and after restoring the vent and side glass window frames would like to know the best method to re-mount the glass to the frames using the BLACK SOFT RUBBER mounting material purchased from Paragon.
  • Mike G.
    • January 1, 1991
    • 418
    Re: 67' VENT/WINDOW GLASS MOUNTING TO FRAME
    A while back, someone described an outstanding method for doing this, using a Black&Decker workmate to press the glass into the frame. The frame was set into a plywood cut-out for support. Someone will chime in with exactly where to find it. Really clever idea. Kudos to its originator.
    • Stephen L.
      • May 31, 1984
      • 3158
      I made the jig suggested in the above response. As it turned out I was able the press the glass into the frame without the jig just using my hands.
      The jig was a cutout of 1/2 inch plywood in the shape of the frame to support the frame as you pushed the glass into the frame. The side of the jig was parallel to the glass edge so that you were pushing into a "square"
      • Jerry A.
        • May 31, 1997
        • 122
        Thanks Mike!! I do have the B&Decker.
        Jerry
        • Jerry A.
          • May 31, 1997
          • 122
          Thanks Steve, Did you use soap or any thing as a lubricant??
          Jerry
          • Stephen L.
            • May 31, 1984
            • 3158
            I don't recall if I used soap, wouldn't hurt though. I was surprised at how easy the glass slipped into the frame. Possibly the glass setting tape I used was of a slightly less caliper..... At any rate they are tight now.
