54 heater pics - NCRS Discussion Boards
54 heater pics
  • Brad H.
    • August 12, 2007
    • 724
    54 heater pics
    Does anyone have any good pictures of the 54 heaters, all views either in the car or on the slab? Thanks Brad.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 54 heater pics *NM*
    • Brad H.
      • August 12, 2007
      • 724
      Re: 54 heater pics
      Damn your fast Roy, just below the #5 paint mark? on yor heater on top face toward dash mine has 1/4 hole at top and 3/4 under that some kind of swivel arm, I see nothing on your's. If that doesn't go their can I snip it off and plug the hole(s) and be okay? Thanks Brad.
      • Roy B.
        • February 1, 1975
        • 7044
        Re: 54 heater pics
        That hole is original , if you plug the hole something awful will happen ( Ha! I don't know what) the swivel arm you mentioned I don't know what that would be, only near the two outlets is a bracket to hold the hot wire connection and a bracket for the heater cable .
        • Brad H.
          • August 12, 2007
          • 724
          Re: 54 heater pics
          Ok now about taking the heater out, will there be any water and atifreeze slopping onto the carpet? Am going to take it apart and check the motor and squirrel cage, does motor unscrew from back of housing and is there anything I can mess up by pulling these two pieces apart, what must I look for when I'm in their, also heater switch checked out ok so must have a look, who can rebuild these in the wash. State area, any one else jump in and give me an idea? Thanks Brad. Ohhhh, who is that guy that builds the shieldings for the 54s, car is near judging now hope to be in Bend Oregon in Sept, what is procedure?
          • Roy B.
            • February 1, 1975
            • 7044
            Re: 54 heater pics
            (Any one else jump in and give me an idea?) What ! It's you and me buddy.
            Here we go= disconnect the heater hoes and blow into one to remove water from the heater radiator .
            Remove two nuts and two lower screws firewall
            Under dash remove heater switch cable and hot lead
            The just pull the heater out
            Remove 5? Screws at back of heater and pull motor and squirrel cage out
            The squirrel cage is pressed on the heater shaft remove it or little screw
            Two nuts hold the motor to the plate remove them and pull motor off plate
            Who rebuilds the motor?
            Corvette has only ONE (brown) hot wire ,Car or replacements have TWO
            PS if the motor runs but so so or noisy drill a small hole near it's end to add oil.
            Some one els will tell you where to get the shielding . Good luck
            • Brett H.
              • January 1, 1996
              • 367
              Re: 54 heater pics
              Man!
              I knew the answer too. Too slow on the draw! LOL
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11323
                Re: 54 heater pics
                I have no clue what the answers are but I'll come in and keep you guys company too.:-)Rich
                ps Watch out, I've been eyeing a nice 54 on ebay! I love white/red int. I was born that year too!
                http://tinyurl.com/2vnvsx
                Roy I think you've given me a bug. I'm liking these old C1's more and more, especially as I'm getting older(maybe not wiser though).
                • Roy B.
                  • February 1, 1975
                  • 7044
                  Re: 54 heater pics "Rich"
                  Old guys go with old Corvettes and look GOOD in a bubble top, that's me in the chair in front BS-ing people!
