carb date question - NCRS Discussion Boards
carb date question
  • Bill S.
    • January 31, 2007
    • 396
    carb date question
    would a 3rd week of nov date carburator be acceptable for a nov 22nd built car.
  • Philip C.
    • December 1, 1984
    • 1117
    Carb dated before engine assy date *NM*
      Hum....
      Why does the carb date have to preceed the engine assy date? I think the AIM shows carbs were installed at the final assy line point while engines were built/run-in at the engine assy plant without gasoline (propane fixture).... Hence, that would make it a 'race' condition with engines and carbs flowing separately from their respective mfgr sites to St. Louis with the luck of the draw being how/when parts were pulled from inventory.
        Re: carb date question
        Bill -
        Should be fine, as the 3rd week of November, 1965, started on the 15th.
        • Philip C.
          • December 1, 1984
          • 1117
          Re: Hum....Hum....Hum
          Hi Jack. Your right a carb doesnt HAVE to preceeed the engine asst date, but I feel it to be a good rule of thumb. The process in which these pieces come together, show time lag from production to assembly, and I find that the carb dates are very close to the assy date of the motor in most cases, Ex; a known orig 1967 motor with a T0327 build date has a 734 carb date and car built 4/25/67. Just my thoughts. Phil 8063
