69 hood latch bracket color - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    My judging manual calls for a gray phosphate finish on the latch brackets. Does anyone know if this is available in a spray can or maybe a home plating syatem? I want it to look correct. I appreciate any help. Thanks, Mark
  • Dick W.
    • 10483
    Re: 69 hood latch bracket color
    I believe that member Grant Wong has the necessary chemicals for the gray phosphate plating. You can contact him thru "View User Profile" in the above tool bar.
    Dick Whittington
      • 11643
      Lighter gray is zinc phosphate, and darker (to black) gray is manganese phosphate. The chemicals are readily available on the web, especially if you look under "Parkerizing" which is the name generally used when the process is applied to firearms.
      I've had a manganese phosphate kit for the last few years and find it easy to use. I've rarely had problems with it and usually get excellent quality.
      Patrick
        • 11643
        Like this:
        Not the kit I have, but you get the idea.
        It is not difficult to find.
        Patrick
        • Greg L.
          • March 1, 2006
          • 2291
          Mark, It's VERY easy to do this type of plating yourself and there isn't a spray bomb out there that is even close in my books! I was going to just order some or the parkerizing solution from the States but "oh no!!...can't ship that up to Canada!!!" was the standard story but then I got lucky and bought some from Grant because he is up here too. His solution worked great so you can't go wrong with either sourse.
          • Gerard F.
            • June 30, 2004
            • 3806
            Mark,
            Here's Grant Wong's gray phosphate being used on a 67 alternator pulley.
            If you want black phosphate also get Grant's OEM black and mix the two or predip
            in the black before you cook it in the gray.
            Very easy to do, all you need is an old crock pot.
            Email Grant from his NCRS profile.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
            • Dick W.
              • 10483
              I've had a manganese phosphate kit for the last few years and find it easy to use. I've rarely had problems with it and usually get excellent quality Work good on Bow Tie cars too????
              Dick Whittington
              • Jeffrey S.
                • May 31, 1988
                • 1882
                Patrick:
                Which of the kits would you recommend for hood latches, etc.-Manganese Black, Zinc Grey, or Charcoal Gray? I think I would like to try this stuff but want to get as close as possible what's correct for my '69. Thanks.
                Jeff
                  • 11643
                  Ha ha ha.
                  Actually, never used it on anything for that car. Really.
                  I've been working on a 66 for some friends, and did a LOT of bolts for that car. Also did several for a 70 recently.
                  Patrick
                    • 11643
                    Jeff,
                    Did you look at the pictures posted last week by Mark Donnally? It showed both colors. My impression is that the latches on the hood are light to medium gray, and the ones on the car body are dark. I noted this same variation in a 70 I'm working on.
                    Maybe we can swap plating time.
                    Patrick
