57 soft top only question - NCRS Discussion Boards
  • Joel M.
    • May 31, 1975
    • 141
    On soft top only cars-- should the convertible top compartment cover display an appx 7/8" hole in the underside stiffner panel at the point the rear center hardtop lug would be located were it a hardtop car.
  • Rob Dame
    Re: 57 soft top only question
    Huh???? if there is a hole on each side it's access to the top shock nuts
    • Roy B.
      • February 1, 1975
      • 7044
      Re: 57 soft top only question "yes" *NM*
      • Mike E.
        • February 28, 1975
        • 5136
        Yes, it should--that was there in all, whether hardtop equipped or not. As you probably know, it was for access to put the nut on the backside of the hardtop hold-down mount.
        • Joel M.
          • May 31, 1975
          • 141
          Thanks everyone *NM*
